M4PDY
20
Hi all,
I want to know the coolant pipe diameter of the two pipes that go to the expansion bottle.
Please help as car off the road until i can replace them.
Paddy
Hmmmm,
No as i have a ibiza 2.0 16v ABF engine but its in a caddy pickup... So i am here fo all your expertice!
as i have standard coolant pipes but want to order reducers so i can put a pickup header tank in.
hope i can still have some help
now bear with me.....
if it was me, i'd measure the pipes on the engine that you already have.
i'd have a Caddy header tank because i want to put it in, and measure the pipes on that.
then look at the numbers i'd have & work it out from that :shrug:
I know that is an option but i dont want to remove the bottom hose on the expansion as it full of coolant and coolant is really pricey nowa days. I thought someone on here may know. I have the caddy one thats not an issue just want the abf ones? :)
the top one is 8mm i remember that much... also fits a 6mm on with pursuasian, but the lower one i cannot remember im affraid
If you dont have the other pipe by thursday ill measure it for you too
EDIT: Also Diameter = Circumference / Pi
lol
that would be fantastic! cheers mate! Is that internal diameter?
Paddy
Hi thanks for that the reason for asking is i want to use joiners between the two sizes so if you could get the sizes for me that would be great thanks!
Paddy
