vinny_cupra
54
Manchester
any 1 had a prob with the cooling fans for the rad?
checked fuses on top of battery, not cracked or blown/melted.
fuses under steering wheel all fine.
put a probe on the connector plug for the rad fan switch and has no power going to it.
going to get auto elec out 2moz.
any1 else got any ideas?
turn on air con as see if there work! shouldnt have power going there if the car doesnt want them on
take the fuses on top of the battery out and check to see if the spade connectors are black or the fuse holder is melted at all. Sometimes the fans draw too much current and the fuse arcs between the contacts (and doesnt melt!!), as the contacts get burnt or coated in molten plastic it can stop working altogether.
ok cheers guys.
basicly the temp gauge goes above 90 and keeps goin if sat still (takes a while) and fans dnt cut in.
but havnt tested for power when its been at 90degrees, will do this 1st fing 2moz.
