redgt
118
are the standard brakes on the ibiza cupra brembo?
does the cupra have an alarm? if so what type
can you replace the headunit??? does the standard headunit have pre outs etc so i can plug phono leads in to run a amp/sub?
what are the standard dampners like if i was to lower on springs?
cheers for the info
add me to MSN if its quicker :D [email protected] :redface:
cupra has 280mm brakes std, no brembo's unless you get a cupra R
std factory fit alarm, and a thatcham approved immobiliser
its difficult to replace the HU, most people jut put a new Hu in glove box or some other free space
is it not possible to link and amp to the unit? like RCA or anything?
also whers the best places on line to buy parts, is it posible to fit a dump valve?
