I drove one of the new twin turbo Audi a6 tdiv6 a couple of weeks ago and it was fairly rapid up to 120 (alconbury runway) and for a diesel it made a very nice noise.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
I was told if a diesel makes a too much noise there's someting really wrong with its.
If you wanted diesel & a nice sound you shoud have gone with an impreza, my 200 bhp 2.0D has a nice engine sound which reminds of a V8 (especially when it's regenerating)
Had a strange rattle on cold start-up which turned into a judder and slight misfire. No warning lights or faults were coming up so they did a couple of compression tests. Compression is a bit erratic but it's got SEAT scratching their heads as to what the cause is. Have to clock up some miles then take it back for more testing. Well weird.
I fixed a Q5 2.0tdi cr last week for the exact same fault your describing, compression was between 24-25 bar (ok) ended up needing all 4 injectors (worn internally)
whats erratic about the compression?
I predict lots and lots of worn CR injectors across the vag range in the not so distant future...
put a pic up if you've got it of the test, compression shouldn't be erratic and all over the place.
wear limit is 19 bar, any thing under then you've got issues, also max variation between cylinders of 5 bar.
my speakers are crap on the laptop but sounds like duel mass flywheel knocking to me (worn)
Yeh get the compression results, the knocking will most likely something driven by the aux belt then as when you put the lights on your putting more load on the alternator.
yeh get the compression results, the knocking will most likely something driven by the aux belt then as when you put the lights on your putting more load on the alternator.
Hiya mate got your pm and the compression results are far too low, send me your engine code i.e cepa, cfffb etc.. and I will double check but they are low for a diesel.
It's especially noticeable when I let off the throttle, does ur still make the sound then????
Just to update you. Yes, it still makes the noise off throttle.
Apologies for hijacking your thread with other stuff mate!
quick copy n paste from elsa mate for cega engine
New: 25 - 31 bar
Wear limit: 19 bar
Max. deviation allowed between both cylinders: 5 bar.
