Cruise control stopped working
dm222
1,487
49
Hi,
Anyone ever had this problem?
All of the sudden it stopped working, I have no idea why.
Found this errors the last one seems to coincide with the time the cruise control stopped working
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Control Module Part Number: 03C 906 024 BK HW: 03C 906 024 BH
Component and/or Version: MM4HV G 3052
Software Coding: 0000071
Work Shop Code: WSC 06402 785 00200
VCID: 68DF5E2B5886005E3C3-5072
1 Fault Found:
28793 - No Communication with ABS Brake Control Module
U0121 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 18
Mileage: 168114 km
Time Indication: 0
Date: 2063.14.31
Time: 18:31:50
Freeze Frame:
Bin. Bits: 00000000
Load: 21.9 %
Lambda: 1.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Absolute Pres.: 272.2 mbar
RPM: 771 /min
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP82.clb
Control Module Part Number: 6R0 907 379 H HW: 6R0 907 379 H
Component and/or Version: ESP8.2i front H04 0005
Software Coding: 110228DB017000B6882C14E280D700401300
Work Shop Code: WSC 04941 000 00000
VCID: 4385A987C6600306C91-8016
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 167
Mileage: 168114 km
Time Indication: 0
Date: 2063.14.31
Time: 18:31:50
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0002
Hex Value: 0x32A2
Hex Value: 0x13B0
Hex Value: 0x0079
Hex Value: 0x7F7F
Hex Value: 0x80F9
Hex Value: 0x0000
01155 - Clutch
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 0
Fault Frequency: 1
Reset counter: 145
Mileage: 168749 km
Time Indication: 0
Date: 2063.14.31
Time: 19:04:24
Freeze Frame:
Hex Value: 0xC000
Hex Value: 0x8000
Hex Value: 0x3202
Hex Value: 0x25B4
Hex Value: 0x0A7F
Hex Value: 0x7F7F
Hex Value: 0x7010
Hex Value: 0x0000
dm222
1,487
49
thinking about it the last error makes sense because the cruise control needs to check if the clutch is pressed or not because from what I remember it stops if you press the clutch.
