billman
120
18
Hello guys. I need the alignment sheet of a cupra leon sportstourer 310 4drive. I have imported the vehicle and it has never been sold officially in this this engine spec in my country. Only in hatchback form. So noone seems to have the correct file to perform the wheel alignment.
Dont worry, in my country it is possible to order it and still every company has different data and no one can do wheel aligment correctly. Last time skoda dealer try that and from that time my car pulls to the right all the time..
It does not matter what alignment you do. The most important thing is that it is aligned straight.
Only toe can be adjusted. Camber is something rhat you can adjust with a sensoren. Only by unbolting and tightening the same bolts.
If both sides toe in is the same degrees 0.12 degrees for example it will be 0degrees for going straight.
@Radek99
If this happens dringend accelersting. Then you have torque steering. Means it will pull to the side with the short axle.
Steering rack can compensatie for that.
Maybe that needs to be reprogrammed.
If it always pulls to one side. Then the car is i correctly aligned
