Cupra Leon Sportstourer 310 4Drive multiple errors when starting
May 22, 2023
Hi all,
Patient is as in title, 2023 model, February. From time to time, 4-5 times in last 3 months I was unable to start a car. I received multiple errors on the dashboard, starting from tyre pressure sensor, pre crash assist sensor up to ignition failure (all at once, 8-9, car is dead). After half an hour (I left, closed car, computer/data bus reset??) there is only one different error: "issue with drive system, go to car service", but I can start it and then the errors are gone and I can drive. No power losses, car drives fine apart from that. Did any of You experience similar issues when starting a car?
I already have an appointment in the dealership, but just looking if someone had similar issues? So I could maybe pinpoint the direction straight away in the dealreship.
Aug 1, 2021
8
Hello,
Similar problemi to me. First time the car was not start with many errors, likes yours. After many weeks in assistence they had change my engine ECU... 2500€. Now, two weeks later same problem Is back. The only differenze Is that now i was able to turn on the ignition.
Did you solve the problemi? What they have change in tour case? Thanks
SWANSWAY CUPRA Dealership
