Cupra R face lift rear lights
sibbocupra
65
Hi,
Does anyone know how to get hold of the face lift 'tick' rear lights? Also are they a straight forward swap or does there need to be coding done etc etc??
I've looked but cant find any threads on it.
Dirt Junkie
52
Yorkshire
they are LED so the car needs coding to them. From seat i think they are around £500. other than that they are a straight swap
Shar
58
Worcestershire
What year is your mk2? Mine is facelift 2011 and I had mine changed to the tick lights. They work fine straight away but they do need coding as otherwise you have a permanent bulb light warning light on the dash.
I have the TPI code SEAT need to use to code the lights if you were getting SEAT to fit.
They look so much better, and are definitely worth the cost.
naz90uk
15
hi bud, do you have the TPI code still? i have tried numerous dealers to get the lights coded but they all seem awkard about it.
Shar
58
Worcestershire
