cutting fans / juddering clutch ?
lukin dappa
221
hi people just wondering since having this new swith or something fitted to do with the fans my cars fan comes on when i start my car cold then goes off after a little while not long at all then just seems to cut in now and again but only for about 5 seconds is this normal. also second ? when someone says about juddering clutch do they mean juddery when u try and pull away just using the cutch or driving many thanks will
VapourTrails
89
London
clutch judder is more evident when driving in gear and you release the throttle if its bad the car will bunny hop at low revs kinda like if you put it in a high gear at say 10 miles an hour. previous car did it only from 1500rpm to 2000rpm it would start with a judder then after about a month it was bunny hoping up the road. it can be costly to get it done im sorry to say.
no clue about the fans only reason there should be a fan on at start up is if the aircon is set to the lo setting and turned on full.
lukin dappa
221
na never use it lol oh thats ok then nothing wrong with that then but the fans think i might be going back to the place i got it from he can start fixin it properly instead of knocking lights out all the time
Dec 3, 2007
2,475
cardiff
i think there is definately a problem with the fan switch. go back and tell them your not happy. it might be wired in wrong or a bad earth somewhere
lukin dappa
221
yeah it weird aint it as before i dont think it worked lol and the management light came on but never overheated and now its on willy nilly and no management light
