CV Boot DIY Kits Question
Havok316
Boost Junky
Jun 6, 2006
1,220
Weston-super-Mare
As my MOT is due soon seat told me my cv boot is split. I was thinking of doing it myself but there are kits out there where you wrap it around the joint and glue the slit down the middle. Would this pass the MOT?
Johnny Leon
143
8
Wondered about this myself. Split boot kits should get you through the MOT but opinion on t'internet seems to be they won't last and you'll end up having to get a new boot done properly anyway. Danger is that if split boot fails and you don't notice for a bit you could end up needing a new CV joint too.
How much for garage to replace outer CV boot anyone ?
Apr 12, 2008
1,197
its not a very hard diy job, take you 2 hours max. just need some grease and the new boot. Might be a bit of a tight fit to put th enew one on, but persaviere!
justsean
202
Cumbria
ive done this a couple times on my old ibiza, DIY job on the CV boot and it passed MOT. but as already said its considered a "temporary fix" should really get it sorted properly!
its a pretty messy job!
henryk
84
fife,scotland
Had a 405 diesel a few years ago, the cv boot was burst so as it was in the middle of December i used the quick-fix(2 halfs & the glue) hopefully to get me through to the good weather. To my surprise two years on and it was still holding ok. As long as there is no grease on the edges to be glued i think they will do a turn.
seatsteve
the cv kit is about 32 quid from seat and about 1 hour if you know wat your doing 2 if you don't know what your doing....there actually pretty simple...
roberts189
Yeh I've done the outer boots on mine but ended up knocking the joint off CAREFULLY because I just couldnt get the boot over it.
Has anyone ever done an inner one as my nearside one is split, can it be changed or is it a case of a new driveshaft??
