Damper/strut torque settings
AL90
488
Sheffield
I'm thinking of replacing the factory springs in my boc with some lowering ones.
I don't really think the job will prove too much of a problem, but I'm wondering if anyone knows what everything needs to be torqued up to again afterwards front and rear?
Deleted member 35176
Quickest way is to put the torque wrench on the bolt on a realtively low setting then turn and increase the torque until it cracks off..simples
DEAN0
Old Git
Feb 1, 2006
5,437
Preston - UK
Be careful - "Breakaway torque" is NOT the same as fastening torque.
These were the values for the MK4 Ibiza 3 door - the Mk 5 is very similar design.
Strut clamp bolt 60Nm + 1/4 turn
lower hub swivel bolt - 20Nm + 1/4 turn
3 bolts for balljoint - 20Nm + 1/4 turn
Rear shock lower bolts - 40Nm + 1/4 turn
Rear shock upper mount bolts - 30Nm + 1/4 turn
Strut top centre bolt - 60Nm
3 top mount bolts - 15Nm + 1/4 turn
Rear caliper carrier bolts - 30Nm + 1/3 turn
I ment on the already tightened bolt not the free turning bolt fastening up.
Plus them values seem reasonable.
AL90
488
Sheffield
nice one.
they are actually a lot lower than I imagined. If I hadn't seen that Id have done them up a lot tighter lol
i suppose the MK4 ones are as good as any!
Cheers Deano :)
DEAN0
Old Git
Feb 1, 2006
5,437
Preston - UK
I know you were talking about the tightened bolt.
My job is to teach people how to use, service and calibrate precision fastening equipment.
I deal with torque and tension all day.
The torque taken to remove a fastened bolt will be at least 10% over the fastening torque and could be over 25% more if rust has taken hold.
Reactions: Woody_72
