Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Here's mine, nothing visible from the driver's seat. You can just see the lens from outside (about the size of a sugar cube) if you know where to look.Anyone got any photos of the camera mounted? My old car (Focus ST) had all the traffic camera gubbins mounted, which essentially meant it was difficult to get a good front view due to acres of plastic on the windscreen. Leon gubbins is a lot smaller but just wondering what the views people are getting are.
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Mobius, C2 wide angle lens, lens extension cable and fitted with capacitors rather than a battery. Purchased from JooVuu.
The first photo shows what you see from the driving position. I've untucked the cable that goes to the lens so you can see where it's mounted.
Taken from down by the gear stick, showing the "camera box" (it's about the size of a matchbox). The mini usb power cable runs under the headlining, down the A pillar and takes it's feed from a piggyback fuse on the cigarette lighter fuse.
The Dashcam thread I linked earlier has more details. Pretty straightforward, I've not done one before and it took me about an hour.
Using Velcro pads means it can be disconnected in a couple of seconds if required. HTH
I bought the nextbase hardwire kit with my dashcam as a bundle and have had no interferance issues to date.
Presumably your converter is mounted behind the dash near the fuse box?
Sent from my SM-G930F using Tapatalk
Some people have tried ferrite cores around the USB cable. I don't have an issue with dab signal with my el cheapo transformer
