messer
287
Engine light come on again, after spending 7hrs at awesome and having a new MAF plus new N75 valve plus a load of vacuum hoses. Any ideas where I can go to have some fault diagnosis work done to see why the light is on again?
Im in St Helens/Warrington and would rather give someone else a try if possible? Not dissing awesome by the way but would just like to try somewhere else if poss
still a bit of a trek but thanks anyway..
Went out for lunch and the warning light has now gone off! I though you had to clear these things before they would go off?? Is this normal?
some will only be on when detecting the fault i believe. When my lambda was on its way out it was on and off for a bit i seem to remember.
Does the car drive ok? No leaks from newly fitted piping ?
car drives absolutely fine its not holding back or anything like that??!
have you tried andys vw in st.helens.
he quite good vag specialist, i know him personally and he pretty clued up
No i havent, do you know his details??
Is that Dave who used to work at IMG? You still doing Seat parts?
