Diesel FR boost gauge install
Dragon1978
139
I am looking at fitting a boost gauge in my diesel FR. The problem I have is I am not sure where to plumb in the pipe work on the engine. I have read it my be possible to tap into either the EGR or plastic hose and fit a bleed valve. Any pics would be greatly appreciated.
Jawa31
19
kent
Hi, I'm trying to work out the same thing but on a Ibiza tdi fr 2004! Not Having any luck either :-( one pic of where to drill hole for pipe and i'd be laughing.
If I come across anything on my searching i'll post you the results mate.
Jawa31
19
kent
Hi Dragon, Had this post earlier!! They should all be similar engines so hope this helps, i'll have a look at mine later to see if it makes sense......
I'm sure these are the same as the Fabia PD130.
When I installed a boost gauge in my friends car I tapped into the large black boost pipe running along the left side of the engine, slightly off to one side so that the fitting doesn't foul on anything.
Matt
__________________
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
Tis easy. Look down the front of your engine, there's the EGR valve and then a big fat pipe going down. Undo the clips to that pipe and take it off. Get a boost tap (I've got one of you want it) and hammer a hole into the pipe. Fit the pipe, voila.
