From the manual is this what you mean
Rear view mirror with automatic anti-daz￾zle function*
The anti-dazzle function is activated every
time the ignition is switched on.
When the anti-dazzle function is enabled,
the interior rear vision mirror will darken au￾tomatically according to the amount of light
it receives. The anti-dazzle function is can￾celled if reverse gear is engaged.
WARNING
In the event that an automatic anti-dazzle
rear vision mirror breaks, an electrolyte flu￾id may leak. This could cause irritation to
the skin, eyes and respiratory organs. If you
come into contact with this liquid, it must
be rinsed with large quantities of water. If
necessary, get medial help.
CAUTION
rear vision mirror breaks, an electrolyte flu￾id may leak. This liquid attacks plastic sur￾faces. Clean it with a wet sponge as soon as
possible.
Note
● If the light incident in the interior rear vi￾sion mirror is obstructed (e.g. with the sun
blind*), the anti-dazzle rear vision mirror
with automatic setting will not operate per￾fectly.
● When the interior lights are on or reverse
gear engaged, the mirrors do not darken
with automatic adjustment for anti-dazzle
position.
● If you have to stick any type of sticker on
the windscreen, do not do so in front of the
sensors. Doing so could prevent the anti￾dazzle function from working well or even
from working
Sent from my Pixel 5 using Tapatalk
Reactions: Barykada
Why is there no feature to dim the rear view mirror? is it me being stupid?
It works on my car but there is no button to turn it off.
You can probably easily notice it if you shine a torch (use a cellphone) into your rear view mirror. It will show up as a darker area in the middle (it doesn't dim the whole mirror, about half a centimeter around the edge remains non dimmed.
Reactions: Barykada
