Do intake systems void factory warranty?
Tonezz
1,038
75
Preston
I know the warranty won't cover something if you have changed a part that they think has a direct consequence of something else breaking.
But I can't seem to find a clear answer online.
AndrewJB
Aug 16, 2007
11,175
485
Maranello
They will try to get out of anything so if you have replaced the intake then engine blows up they will blame that...
If engine does blow up just remove the intake ;)
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
You probably can't find a clear answer because there isn't one.
If you put an intake on and your electric windows stop working then they aren't going to refuse the work, but if they can in any way relate it to a part you've fitted then don't be surprised to find the fault is no longer covered under warranty.
Aok82
155
Finland, Uudenmaanlääni
The answer is really simple.
It does void warranty.
Everything that is not original factory part in engine bay voids warranty. Even if it has nothing to do with (for example engine blow up).
But a lot decisions are made by the dealers only, so some might look things a lot through fingers and some not. Thats the only difference.
Tip: if you service your Seat @ seat dealer and you want to keep the warranty on, uninstall enginebay mods before, because they will take photo on each maintenance especially if there is something in there that does not belong.
Ref: my friend lost a battle of a blown engine with only 28000km on the clock.
He had installed forge dump valve and thats it. NO WARRANTY, because engine modded.
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
But it's not that clear cut, the warranty covers more than just the engine, and as said previously if it's something that can be related to the fault in any way then of course they will use this to get out of doing the repair under warranty, but it won't void the entire warranty on the car, you'd still get an interior trim fault sorted if you had a forge dump valve fitted for instance.
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
I think it's on a case by case really, if you want to be cautious then remove the mods before you take your car in, otherwise just hope they use common sense........unlikely but can happen.
MJ
Public transport abuser
Apr 22, 2008
5,505
13
Manchester
m.facebook.com
Common sense plays a big part. Sometimes dealers can just be arse holes but on other occasions they just have to cover their own back. Which dealer wants to end up with a £10k bill because they can't justify a warranty claim on a standard engine or gearbox failing with no outside influences?
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
Tis true
SWANSWAY CUPRA Dealership
