Just tried this on my girlfriends Altea FR.
I changed the cambelt last month, it's done 66k. She only does short journies, and I have noticed before it sometimes goes a little flat but a good thrash clears it up.
Anyway, It's had a fault code for a while about the injectors. It just keeps coming back. So, I've just changed the injector loom in an attempt to clear it. It didn't work, just came back straight away.
The DPF light came on too recently, been trying to do the regen but just couldn't get it to work at all. Then I noticed if I cleared the codes it'd let me do the regen. But after a while the fault code pops up again and the regen stops. If I go and clear the codes it'll kick back into regen again. I've had to keep cyclcing it like this, clearing the codes, then checking to see if it's still doing the regen. It was working great, just got it down from 61% to 24% then disaster! now the glow plug light is flashing as well as the DPF light, and the car is completely flat as a fart and gutless. There is no power, it won't rev. I'm guessing it's in limp mode, but even turning it off and waiting a while then starting doesn't cure it.
I've got 2 codes:-
Address 01: Engine Labels: Redir Fail!
Control Module Part Number: 03G 906 018 EC HW: 03G 906 018 EC
Component and/or Version: R4 2.0l PPD1.2 G 9135
Software
Coding: 0050072
Work
Shop Code: WSC 06401 785 00200
VCID: 6AC50FC23CEF
2 Faults Found:
008194 - Particulate Trap Bank 1: Efficiency Below Threshold
P2002 - 006 - Short to Plus
004706 - PD Unit Injector: Cylinder 1 (N240): Regulation Range Not Reached
P1262 - 007 - Short to Ground
I'm now panicking thinking I have completely wrecked the DPF. Is this the case? Just parked the car up for the night hoping the ecu might calm down a bit by the morning...but I'm not holding out much hope :-(
