bruceR
2,589
680
Monifieth, Dundee
Ok folks so I recently replaced both front door lock modules with OEM units, had a blonde moment when I forgot to refit the inner cable, but all working and locking.
So now I notice that I’ve got to pull the driver outer handle twice to get door open but all others just once.
Is there something I need to reset or will I need to get VCDS to reset it???
Cheers for any help
Sounds like you need adjust the little cable that goes from the latch in the door to the outside handle easy todo a cover and a screw in the side off the door then remove the lock and then pull the plastic tab out off the side off the handle and move it up a bit rebuild and try
