Dynamic Navigation System Aux input
hyphon12
Daft Member
Jun 7, 2011
1,106
Scottish Borders
Right I'm wanting to put a phono-jack socket input in my LCR so I can plug in my MP3 player. I've got the dynamic Navigation system and 6-CD changer. Thing is I want to put an aux input in without losing the CD changer.
I seen there is a 10-Pin DIN connector on the back of the unit for Aux/Video input and an "Aux" option on the unit, handy enough I had a cable spare that fits to it and has a RCA input. Problem is when I hooked it up it didn't work. So now I'm trying to find a proper cable to get it work but can't find anything for sure.
Has anyone done this or got a good idea?
Cheers :)
DMackie
110
Aberdeen
I know that on the audi system you have to use vag com to make the aux option available and then reboot the device for it to work.
I looked into doing this a while back.
DMackie
110
Aberdeen
Ok cool, quite tempted to buy one then as id like to run an aux cable to the arm rest and have ipod located there.
What are your thoughts on the unit?
hyphon12
Daft Member
Jun 7, 2011
1,106
Scottish Borders
Its ok, it came with the car. Best thing about it is obviously blends into the interior. Sat Nav is a bit slow though and if using the original Nav Disc its hugely out of date. Another thing is the CD drive doesn't play music (used for Nav disc) so you need a CD-Changer. But it good enough for what I want, especially when the sound is very good.
DMackie
110
Aberdeen
Ok cheers man, ive changed my tape player hooked to a cd changer with an aftermarket cd player with aux but i want a more oem look so would like a rear aux cable to run along the floor to the arm rest.
