Ecotek Powerboost engine decoker?
keetdi
Hi ye m8 i have i used it the other night and the cars running great.. easy to use definitly did something as about halfway through using the tin, deposits of soot and muck bellowed from the exhaust and ran clear again after about 2mins.. i got mine off ebay £13.99 +£3 p+p.. The car now has very smooth acceleration and more economical.... 51 plate tdi 110 with 127500 on clock
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
I also used this. Found it made the car run that little bit more smother. Nice and easy to use, just make sure you disconnect the MAF before doing it.
Nov 29, 2007
736
Mansfield, Notts
didn't fifth-gear do a test of all these so called power products and end up proving that in every case engine bhp actually went down by 2-3 bhp. The link Lee69 posted adds more weight to the response:
Its all in ya head - don't waste your money!
chrisphysics
SEAT Lover
Jun 22, 2008
95
Sheffield
Firth gear tested fuel additives this is different, not that i'm saying it works. (Haven't tried it)
lukecupra2001
Smoogie And Proud
Jul 25, 2005
338
middlesbrough
i used it on my clio 172 years ago and just put a tin through the wifes 1.1 206 and they were both alot smoother and ran alot better.not sure bout the performance but so much smoother n free revving.i dont understand why so many people on here slate poducts, if people want to use them its up to them dont need to see things about trading standards or whatever it was.
if want to use it go ahead dont let other people put you off
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
we dont slate products, peoplea are giving opinions on them, if thread starters didnt want opinions then they wouldnt ask....
all i can say is that if you regularly service your engine, keep it clean, use quality fuel. i.e optimax etc
then you will not have a problem with the issues this powerboost thingy states.
