Bg224 then, although it says bg44 can be use in either bg244 is diesel specific.
I'm leaning towards an injector issue now as I always use either bp or shell but just mentioned tithe misses and she told me she filled the car up at sainsburys last time! I hate supermarket fuel.
I'll do a tank of bg244 then after that's empty start using millers. As well as doing the egr gasket. Might chuck a new panel air filter in too.
If all that fails then its in to the stealers for an overhaul as its still got a warranty on it.
Well would people still use this smaller gasket even if ur car dont have problems ie my Cupra pd160 is running sweet as it should be and don't want any negative affects
For £2 try it, car might run even better, if you put it in and it makes it worse..take it out agan
