Electric Window Console on Driver's Side
Aug 11, 2020
Hi,
I'm not very technical and have been struggling with a small issue not worth going to a garage about. The restraining fastener on the console beneath the top cage (?) has disappeared and I can't figure out what I need to fix this. The two holes facing each other are different sizes, the top one approx. 2mm and the bottom one approx 5mm. Somebody suggested that it needs a popper to clamp them them together - is that correct and, if so, where would I source this?
Rgds,
Cornelius49
chriswales6
294
47
If you're talking about the panel holding the electric window switches in the driver's door. The best thing to do is take the door card off and make busy with the glue on the underside to hold it in.
Personally I'd use a multi purpose adhesive like Uhu instead of superglue. If the clips are very broken, then reinforce things with some bits of paper covered in glue over the joint. Helps spread the shearing force on the joint.
