stevie steve
322
Clevedon
My león has full electric windows. I can control all from the door as usual Up and down.
However the back left door switch will only take the window up and not down.
Is this a switch problem?? Cant see it being anything else
If so, is it a door panel removal job of do the switches (fingers crossed) prize out with a flat blade screwy??
My front passenger side did this and yes its a replacement switch and no you don't need to remove the door card, the switch pops out, you can also use any single switch (Not fronts afaik) i bought a rear switch, removed it from its housing and put it in the front one.
I had a faulty switch, I actually opened it up and fixed it. All it needed was a bit of clean up and replacing a PCB track. Mainly because at the time I couldn't find a suitable replacement! :)
I still need to do the drivers one, the first touch is temperamental going down.
EXCELLENT - just what I needed to hear. Might go and have fumble in the dark with a torch later :whistle: Nice one guys
