DEAN0
Old Git
Feb 1, 2006
5,463
Preston - UK
Seeking knowledge from the group.
I needed to replace my drivers side door lock actuator. ( 2018 3 door Cupra )
( Drivers door would not unlock with the key fob )
Used a genuine SEAT part and the swap over was simple enough.
Everything seems to operate as normal on the locking mech.
Door now unlocks and locks via keyfob, inside buttons and external key slot.
However - when the car autolocks ( over 6mph ) - it now disables my drivers side window so I can't bring it down.
And the inside lock button no longer goes orange when the autolock is active.
( Passenger window still operates as expected. )
If I unlock the car using the inside button - the drivers window is active again and works as it should.
Anyone know if new door lock actuators need some sort of coding after fitting ?
Any other thoughts what might be causing the auto lock to disable the drivers side window ?
In case it helps anyone.
Even though the lock part numbers are the same - it turns out that some have the "safe lock" motor installed - and some do not.
The fix was to use VCDS - go in to the door electrics and tell the car the new lock does not have a "safe lock" installed.
All now working as it should.
Reactions: tracktoy and DaveS
