Hi Folks.
Could anyone shed some light on the electrical problems I’ve recently encountered on my Bamma’s tailgate?
Rear fog lights have stopped working (fuse?).
When you press the brakes, the fog light shows on the dashboard (is this a factory designed warning of fog light failure?)
Turn on the sidelights/headlights, the fog light shows on the dashboard again (same warning as above?)
Brake lights work as normal EXCEPT when fog lights are switched on, then high level brake light doesn’t work
Central locking works EXCEPT on tailgate. When you pull on handle, you can hear central locking motors whirring but door won’t open.
Rear window wiper has stopped working but I suspect motor has failed because the blade used to stutter across the window, not wipe smoothly.
Reverse lights don’t work, but they have been faulty since I bought the car and I suspect is unrelated.
If anyone can help with any of the above faults, it would be greatly appreciated.
Tully
Tully
