S1LRD
49
Somerset
s26.photobucket.com
Want to hardwire my snooper in via the rear of the cig lighter but i've came across these 3 wires......... I asume the brown is the negative, but which of the other two do i run my Positive feed off??
Thanx
one will be a light.... as most cig lighters 'light' up
the blue? one looks smaller guage, so I would guess that's the one for lights.
is the other one red? in the middle? my bet would be that's the +ve
sorry to sound like a retard, but I'm pretty colour blind.
have you got a multimeter ?? As mork said i'd go for the red being the +
I'm guessing the red is positive, white/blue being switched, brown negative.
The blue/white wire looks like the one i wried my boost gauge too behind the light switch which is part of the dash lights/dimmer adjuster.
you are gussing the polarity of the wires for hardwiring your snooper?
:confused:
Volt meter dude... it will save you buying another snooper from reversing its polarity and popping it!
All fitted, went with the red wire. i know it was a little guess, but i was using a proper hardwire wiring kit with a converter and fuse, so at worst i would of blown a fuse! all went well and is in nice and neat. thanx for the help, i'll get hooked up with a multimeter for next time.
