Electrics to door
ukdan
Hi guys. i got a problem with my 2000 Toledo. My front passenger door window dropped into the door because the regulator went. I took it to a dealers where they got the window out and wedged it up. They also removed the old regulator. I have sice replaced the whole plate on the door so that bits ok. My problem is that since i got the car back from them i've had some electrical probs with the door. Bear with me here..... The central locking doesn't work on it, The mirror doesn't work at all, the light to the window switch isn't lit but the switch works whereas the switch on the drivers door (for passenger window) doesn't work. However, the speakers work and so does the light on the door. I've checked the connector behind the trim in the footwell and that seems fine. Is there anywhere else i can look? Your help would be appreciated here. Thanks in advance guys.
ukdan
Its me again. Something just occurred to me. All the faults are linked to controls on the drivers door so is there a connector anywhere that might have come loose or a fuse maybe?
ukdan
Hiya.
Thanks for your advice. Having spoken to the dealers to see if they did anything to the car, i discovered that the plug for the motor works more than just the motor ie, central locking, window switches. I thought that the replacement i bought off ebay was a good 'un but its seems not. However, i did make 1 good winder out of 2 bad ones by swapping the motors over. Hey presto!!!! It all works fine now. Thanks for all your help guys. Who knows, i might be needing u again the future.
