TDI to petrol conversion, would the interior fuse box and wiring loom need to be changed too?
Sent from my SM-N9005 using Tapatalk
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
I cant see how changing would require the interior loom to be changed. Granted there will probably require a rather large wiring merge. But there are other factors that you must do when changing a diesel car to a petrol engine swap.TDI to petrol conversion, would the interior fuse box and wiring loom need to be changed too?
I'm sure it depends o the model of the car.The car is worthless as it is, it's cheaper to buy a donor and convert it to something different (cooler) I'm not buying everything separate it'll be a full car I just wanted to know if anything on the dashboard side would need changing, I know what's needed for a normal conversion just not tdi to petrol, if the fuse box layout isn't any different then I won't touch the interior
Which car? What tdi engine to what petrol?Yeah, plus it's a conversion that hasn't been done as far as I'm aware yet
Ah cool! Those are pretty rare over in the UK? Right? The best thing you can do is compare the golf 1.9 to the golf 2.8 since the cordoba is also based off the golf chassis. Try finding the wiring diagrams for both cars. But I think you will find they're pretty similar.The cordoba estate and I'm looking at putting a vr6 in it
Pretty rare yeah, mine is 1 of 22 in the UK from research, and I have,the platform is the same from the cordoba and mk3 golf so it's a bolt in conversion using factory mounts and plugs etc, the only thing that was racking my brain was the interior wiring, like will the fuse boxes and more importantly the fuse and relay layouts be the same between petrol and diesel, if they are then I can get away with leaving the dashboard and interior alone. Only issue I'm getting so far is the clocks from mk3 won't fit my dash, but the mk3 dash is wider than mine, but I can get the immobiliser removed to solve that issueAh cool! Those are pretty rare over in the UK? Right? The best thing you can do is compare the golf 1.9 to the golf 2.8 since the cordoba is also based off the golf chassis. Try finding the wiring diagrams for both cars. But I think you will find they're pretty similar.
The not your average bus! Yeah you make me want to buy one over here in Germany. Okay so what you should do is fly your ass to mainland, buy a petrol one for 500 pounds, drive it back to your place and use it for parts. Then you have all the petrol starting parts you need! Just swap over to the right hand drive body.Pretty rare yeah, mine is 1 of 22 in the UK from research, and I have,the platform is the same from the cordoba and mk3 golf so it's a bolt in conversion using factory mounts and plugs etc, the only thing that was racking my brain was the interior wiring, like will the fuse boxes and more importantly the fuse and relay layouts be the same between petrol and diesel, if they are then I can get away with leaving the dashboard and interior alone. Only issue I'm getting so far is the clocks from mk3 won't fit my dash, but the mk3 dash is wider than mine, but I can get the immobiliser removed to solve that issue
You breaking the Internet again lolSo it's a 1.9tdi to a 2.8 vr6
You make it sound way simpler than it isThe not your average bus! Yeah you make me want to buy one over here in Germany. Okay so what you should do is fly your ass to mainland, buy a petrol one for 500 pounds, drive it back to your place and use it for parts. Then you have all the petrol starting parts you need! Just swap over to the right hand drive body.
Or do a big TDI swap like a 3.0 or 2.5
I do tryYou breaking the Internet again lol
This is going to be awesome haha
Just saying man if you want a fast estate and you don't want to go with an A4 wagon as the ground works, then it would be best to start with a petrol platform. ******* hell you can get an A4 quattro with a 2.8 v6... I know I know boring and not super unique. I'm just trying to save your wallet and your headaches. By the time you complete the swap and have everything done you'd have bought an a4 with some mods. Or a leon 4wd with the vr6You make it sound way simpler than it isI'm still deciding completely what to do so no idea whatll happen yet
I've had an a4 estate before (insert picture hereJust saying man if you want a fast estate and you don't want to go with an A4 wagon as the ground works, then it would be best to start with a petrol platform. ******* hell you can get an A4 quattro with a 2.8 v6... I know I know boring and not super unique. I'm just trying to save your wallet and your headaches. By the time you complete the swap and have everything done you'd have bought an a4 with some mods. Or a leon 4wd with the vr6
If you really wanted to do the cordoba estate by all means do your thing I'm here to support you. Just trying to throw in a different perspective.
An A4 Avant B5 generation with 1.9tdi 90hp same spec as your car 1285kgI've had an a4 estate before (insert picture here) that was something different too, over here vr6's aren't that expensive, full running and driving car with rust and no mot for less than £600, factor in what the engine costs alone and it's fairly cheap. I've had so many diesels I'm genuinely bored of them, plus the overall weight of the cordoba is way less than an a4 quattro so power to weight is shifted a lot, ah I don't know the money isn't a problem because I've already gone overboard with the car as it is, and vr6 conversion was the cheaper option compared to spending 10k on building the 1.9 just to get close to 300 in it
