Engine cover wanted
STU3Y
1,271
Kent
Is this for the taller mounts? When i search google seems to be the wider rubber one?
STU3Y
1,271
Kent
I think I need the front ones and the back right one.
STU3Y
1,271
Kent
As far as i can see they are like ball joints that push into the rubber on the cover itself. Like these
lc_allan
Northern Monkey
Sep 15, 2006
3,389
No the number is for the rubber bungs that fit into the holes on the engine cover. These then push onto the tall mounts that are fitted to the engine.
lc_allan
Northern Monkey
Sep 15, 2006
3,389
If your car didn't come with a cover then yes you will need both the tall mounts and bungs. There should be 4. Well there is on the Cupra. Not sure on the other models.
STU3Y
1,271
Kent
Just to clarify, ive bought the cover with the three rubbers in it. I have the rear left mount still on the engine. Not having seen the others I think that all I need are 3 of the ball studs shown in the picture above, Just want to know if anyone has any spare or kniws where I can buy online?
STU3Y
1,271
Kent
Update...Having tried to find out what size thread these use I discovered that the threads on the manifold were stripped, which explains why I had no cover in the first place . I have therefore managed to get a couple of larger bolts in and used plastic bushes on top to act as the ball, seems to have done the job.
STU3Y
1,271
Kent
For anyone that does want the genuine ones above Dave at seremotors can supply them for
3.35 each or you can get them at vwgenuineparts.co.uk for 3.37 each
