Chrisd1983
Newton Abbot
Evening All,
I have recently have an EML come on, I have scanned using VCDS and have the following errors -
Thursday,07,September,2017,18:56:59:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZGR005911
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CZEA) Labels: None
Part No SW: 04E 906 027 HF HW: 04E 907 309 BJ
Component: R4 1.4l TFS H22 2326
Revision: R6H22---
Coding: 01190032232419080000
Shop #: WSC 00049 770 00128
ASAM Dataset: EV_ECM14TFS01104E906027HF 001004
ROD: N/A
VCID: 6FEBA5E7B61FDE667D9-803A
No ASAM data for: "EV_ECM14TFS01104E906027HF" (SE37)
3 Faults Found:
21742 - ROD - Unknown Error Code
- 00 [096]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 66
Reset counter: 237
Mileage: 17140 km
Date: 2000.00.00
Time: 00:00:00
17125 - ROD - Unknown Error Code
- 00 [237]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 74424 km
Date: 2017.09.05
Time: 17:44:02
17140 - ROD - Unknown Error Code
- 00 [237]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 74424 km
Date: 2017.09.05
Time: 17:44:02
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 3Q0 907 379 J HW: 3Q0 907 379 C
Component: ESC H32 0392
Revision: 00000000 Serial number: 61225000001563
Coding: 18EE8A92242029710080060141C4241851249400608224F200210070C002
Shop #: WSC 00049 770 00199
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 418F335FD00B1816DBD-8014
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 65
Mileage: 41914 km
Date: 2016.07.25
Time: 10:14:44
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 H HW: 5F0 907 044 H
Component: Climatronic H04 0911
Revision: 00001K09
Coding: 04100004200100011005004000101000
Shop #: WSC 00049 770 00103
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 2B5371F74287E246111-807E
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
No fault code found.
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0173
Serial number: 01061513101035
Coding: 0B000A42420100DB0B244000B10403281000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 891F6B7F28BB105643D-80DC
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119
Component: WWS370 150427 041 0574
Serial number: 150430211022
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150750UES
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000032487801
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 21058708
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391513202476
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_SE37.rod
VCID: 43833957CA170A06C91-8016
Address 15: Airbags (J234) Labels: Redir Fail!
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0200
Revision: -------- Serial number: 003P4PA286SP
Coding: 98CCC000000000005C0000CC008800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X_SE37.rod
VCID: 7F0B75A7E67FAEE6ED9-802A
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 000 405 15
Component: SideSensor_Df 008 0887
Serial number: 3576U0000007C9AC641Q
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 454 000 405 15
Component: SideSensor_Pf 008 0887
Serial number: 3586U0000006F825F31L
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 454 801 705 15
Component: SideSensor_Dr 111 0148
Serial number: 3516R1AB2AE06000000A
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 454 801 605 15
Component: SideSensor_Pr 111 0148
Serial number: 3526R8044A706000000$
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 454 802 404 15
Component: FrontSensor_D 114 0149
Serial number: 3556V416A3A060000004
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GD HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 21051504400588
Coding: 1400
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB.rod
VCID: 7EF588A3E175A7EEE6F-802B
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5F0 920 973 HW: 5F0 920 973
Component: KOMBI 303 6420
Coding: 27A50A002980260001086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: E9DF4BFF08FBB056A3D-80BC
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003548993
Coding: 030100F42F085700EB0002C8080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_AU37.rod
VCID: 75E7978FD443E4B6B75-8020
Generator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B1065230415
Coding: 002000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001504211615
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000150100636
Coding: 00100220DC01040100001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 479B2D47FE2F2626159-8012
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000150383567
Coding: 00100220DE01040100001000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 46852043F9253F2EEEF-8013
Address 55: Xenon Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 048C000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: F5E7178F544364B6375-80A0
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5QA 035 858 HW: 5QA 035 858
Component: MU-S-ND-ER H24 0241
Serial number: SEZAZ2R0147701
Coding: 04731001FF0A000011111101008808002F0000000000000046
ASAM Dataset: EV_MUStd6C3TSAT 001015
ROD: N/A
VCID: 0401FA4B8F99CD3EB0B-8051
Subsystem 1 - Part No SW: 5F0 919 604 A HW: 5F0 919 604 A
Component: ABTm_Std2_Nav H43 1028
Serial number: SEZ8Z9RHG0016P
Subsystem 2 - Part No SW: 6P0 919 866 HW: -----------
Component: ECE 2015/16 --- 0430
Serial number: --------------------
No ASAM data for: "EV_MUStd6C3TSAT" (SE37)
End ---------------------------------------------------------------------
Does anyone what these ROD errors are?
Thanks!
Chris
I don't think that is compatible with the 5F Leons you need version 15.? or higher which of course will not work with a pirate lead.
It certainly is compatible with 12.12.0 as I did some coding when I first got the car.
Anyway the car is going into Seat on Monday of which I'm sure I will be provided even further insight of the error code.....and the crap designed rear dampers
I'm sorry I have to disagree, version 12.12 is December 2012 so will not have all the information for later cars, hence the unknown ROD file info and no ASAM data. Latest version is 17.8 (August 2017).
