Evening All,
I have recently have an EML come on, I have scanned using VCDS and have the following errors -
Thursday,07,September,2017,18:56:59:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Chassis Type: 5F (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: VSSZZZ5FZGR005911
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CZEA) Labels: None
Part No SW: 04E 906 027 HF HW: 04E 907 309 BJ
Component: R4 1.4l TFS H22 2326
Revision: R6H22---
Coding: 01190032232419080000
Shop #: WSC 00049 770 00128
ASAM Dataset: EV_ECM14TFS01104E906027HF 001004
ROD: N/A
VCID: 6FEBA5E7B61FDE667D9-803A
No ASAM data for: "EV_ECM14TFS01104E906027HF" (SE37)
3 Faults Found:
21742 - ROD - Unknown Error Code
- 00 [096]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 66
Reset counter: 237
Mileage: 17140 km
Date: 2000.00.00
Time: 00:00:00
17125 - ROD - Unknown Error Code
- 00 [237]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 74424 km
Date: 2017.09.05
Time: 17:44:02
17140 - ROD - Unknown Error Code
- 00 [237]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 74424 km
Date: 2017.09.05
Time: 17:44:02
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 3Q0 907 379 J HW: 3Q0 907 379 C
Component: ESC H32 0392
Revision: 00000000 Serial number: 61225000001563
Coding: 18EE8A92242029710080060141C4241851249400608224F200210070C002
Shop #: WSC 00049 770 00199
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_SE37.rod
VCID: 418F335FD00B1816DBD-8014
1 Fault Found:
16401 - Tire Pressure Warning
C102D 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 65
Mileage: 41914 km
Date: 2016.07.25
Time: 10:14:44
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5F0 907 044 H HW: 5F0 907 044 H
Component: Climatronic H04 0911
Revision: 00001K09
Coding: 04100004200100011005004000101000
Shop #: WSC 00049 770 00103
ASAM Dataset: EV_ACClimaBHBVW37X 003017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 2B5371F74287E246111-807E
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
No fault code found.
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0173
Serial number: 01061513101035
Coding: 0B000A42420100DB0B244000B10403281000000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 891F6B7F28BB105643D-80DC
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119
Component: WWS370 150427 041 0574
Serial number: 150430211022
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150750UES
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000032487801
Subsystem 4 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 21058708
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391513202476
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_SE37.rod
VCID: 43833957CA170A06C91-8016
Address 15: Airbags (J234) Labels: Redir Fail!
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0200
Revision: -------- Serial number: 003P4PA286SP
Coding: 98CCC000000000005C0000CC008800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X_SE37.rod
VCID: 7F0B75A7E67FAEE6ED9-802A
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: ----------- HW: 454 000 405 15
Component: SideSensor_Df 008 0887
Serial number: 3576U0000007C9AC641Q
Coding: 2D2D2D
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: ----------- HW: 454 000 405 15
Component: SideSensor_Pf 008 0887
Serial number: 3586U0000006F825F31L
Coding: 2D2D2D
Crash sensor for side airbag; rear driver side:
Subsystem 3 - Part No SW: ----------- HW: 454 801 705 15
Component: SideSensor_Dr 111 0148
Serial number: 3516R1AB2AE06000000A
Coding: 2D2D2D
Crash sensor for side airbag; rear passenger side:
Subsystem 4 - Part No SW: ----------- HW: 454 801 605 15
Component: SideSensor_Pr 111 0148
Serial number: 3526R8044A706000000$
Coding: 2D2D2D
Crash sensor for front airbag; driver side:
Subsystem 5 - Part No SW: ----------- HW: 454 802 404 15
Component: FrontSensor_D 114 0149
Serial number: 3556V416A3A060000004
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 GD HW: 5Q0 953 549 F
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 21051504400588
Coding: 1400
ASAM Dataset: EV_SMLSKLOMQB 017001
ROD: EV_SMLSKLOMQB.rod
VCID: 7EF588A3E175A7EEE6F-802B
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 5F0 920 973 HW: 5F0 920 973
Component: KOMBI 303 6420
Coding: 27A50A002980260001086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: E9DF4BFF08FBB056A3D-80BC
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003548993
Coding: 030100F42F085700EB0002C8080F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_AU37.rod
VCID: 75E7978FD443E4B6B75-8020
Generator:
Multifunction unit control module:
Subsystem 2 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B1065230415
Coding: 002000
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185703001504211615
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000150100636
Coding: 00100220DC01040100001000
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 479B2D47FE2F2626159-8012
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000150383567
Coding: 00100220DE01040100001000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 46852043F9253F2EEEF-8013
Address 55: Xenon Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0080
Revision: -------- Serial number: --------------
Coding: 048C000009000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB.rod
VCID: F5E7178F544364B6375-80A0
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5QA 035 858 HW: 5QA 035 858
Component: MU-S-ND-ER H24 0241
Serial number: SEZAZ2R0147701
Coding: 04731001FF0A000011111101008808002F0000000000000046
ASAM Dataset: EV_MUStd6C3TSAT 001015
ROD: N/A
VCID: 0401FA4B8F99CD3EB0B-8051
Subsystem 1 - Part No SW: 5F0 919 604 A HW: 5F0 919 604 A
Component: ABTm_Std2_Nav H43 1028
Serial number: SEZ8Z9RHG0016P
Subsystem 2 - Part No SW: 6P0 919 866 HW: -----------
Component: ECE 2015/16 --- 0430
Serial number: --------------------
No ASAM data for: "EV_MUStd6C3TSAT" (SE37)
End ---------------------------------------------------------------------
Does anyone what these ROD errors are?
Thanks!
Chris
Revision: R6H22---
ROD: N/A
3 Faults Found:
- 00 [096]
Freeze Frame:
Fault Priority: 0
Fault Frequency: 66
Reset counter: 237
Mileage: 17140 km
Date: 2000.00.00
Time: 00:00:00
- 00 [237]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 74424 km
Date: 2017.09.05
Time: 17:44:02
- 00 [237]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 74424 km
Date: 2017.09.05
Time: 17:44:02
1 Fault Found:
C102D 00 [008] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 65
Mileage: 41914 km
Date: 2016.07.25
Time: 10:14:44
Revision: 00001K09
Air quality sensor:
Coding: 0BC5FD
Coding: 0031051001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 1400
Generator:
Coding: 002000
Coding: 8103
ROD: N/A
Thanks!
Chris
