Engine management light
May 26, 2019
11
Took delivery of my Seat Leon Cupra 290 today, I noticed when I turn the ignition on the yellow engine management light is on above the digital cockpit.
However, once the car is started it disappears.
Is this normal?
SteveGSXR600K1
579
189
I think it is just showing you that the engine management light indicator is functioning. People have been know to sell their car with an issue, which would normally show an engine management light, but remove the bulb or tape over it, so you're not aware that there's an issue. If yours stayed on after the car was started, then there would be an issue.
Reactions: Butty and xyz
CupraGeezer
357
163
Also an MoT requirement for it to work that way along with things like the ABS warning light.
Reactions: xyz
