esp light
seattoledotdi
anyone in NG12 (Nottingham) with vag com Hex can cable to diagonise esp light fault on toledo tdi 2005 model.
thanks.
seattoledotdi
esp
hi
yes its on all the time. the switch does not turn it off.
James_R
5,686
109
37
Manchester
i dont mean to put the fear of god into you but i've seen 5 cars around the same year with
exactly the same fault and its been the brake pressure sender inside the ABS pump, which requires a new abs pump. If you get it on vag com or a code reader it should come up with '-sender-1-g201-brake pressure sensor-'
Get a private warrenty if you dont have one.
seattoledotdi
esp
hi
thanks for the input. I hope its not that !
still waiting for an offer of vag com help.
seattoledotdi
esp
Hi
Thats what i am hoping.
Any suggestions what I could look at while I wait for a vagcom offer.
James_R
5,686
109
37
Manchester
Sorry i'll explain a little more in-depth.
The several vehicles that i've seen have expecienced these symptoms:
-TCS or ESP light, out of the blue, comes on perminently
-It cannot be turned off with the button on the centre console
-when the fault memory is read it shows a fault with the brake pressure sensor
-the fault is fixed and not sporadic
The fault doesnt effect the ABS and doesnt bring on the ABS light, only the TSC/ESP. Normal braking is not effected. It tends to effect vehicles from 55reg to 06reg (only new leon, toledo and alteas)
The only way to rectify the fault is to replace the pump (hydrolic unit) because the sensor is intergrated. Once the new pump is fitted the sensors which the ABS and TCS/ESP use must be re-calibrated.
There doenst tend to be much that goes wrong with the TCS/ESP on new leons, toledos and alteas, its one of the systems VAG have made a good job of designing.
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
Is it on all the time, or does it come on (and stay on) after 8-10 minutes into a journey?
seattoledotdi
esp
hi
initially when it came on it could be turned off with the switch. but then it would light up again after a short drive.
Now it is on all the time and the switch has no effect.
thanks
seattoledotdi
esp
come on guys (and guls)there must be some one out ther with vagcom who can oblige.
James_R
5,686
109
37
Manchester
if your willing to travel to manchester i'll do it for you, no charge
seattoledotdi
esp
Thanks a lot for your offer but that is a bit far for me at the moment.
I am hoping for some local help.
kevinmac87
just bought an 03 leoan cupra r and the same things happening with me. dealer ran the diagnostics and its showing G214 brake pressure sender. this mean thats fdeffo the problem?
James_R
5,686
109
37
Manchester
not sure if the sensor is in the pump on that model to be honest mate.
kevinmac87
Well the delaer said it was wanting him to do wireing checks bt theres no delaer local to me. The dealer i went to was jst where i bought the car, but the guy reckoned it looked like it myt need a new master cylinder. Any advice i aint the most mechanicly minded person
