Exhaust sounds blown but it's not!? LCR
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
https://vimeo.com/127882586
Hi guys, have a listen to this video.
My exhaust is perfectly sealed but it sounds like it blown especially when cold. It sounds worse in person and I'm actually embarrassed to start it up in from of people!
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
Tried ur coil pack? May be ur down pipe it has the mesh over it, it may have split.
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
I've not tried coilpack mate and the downpipe and de-cat pipe are only 2 months old and leak test around all joints and flexi showed nothing.
I've heard people going on about they're SAI making they're car sound like a tractor because the pump wears out. But, I don't know if the LCR even has SAI?
The noise definetly sounds like it's inside the exhaust around the de-cat pipe area but it just doesn't make sense.
The car also runs amazing
Bigjohn84
May 5, 2015
2,330
I'd need to really have a look myself mate, if your up for it I can meet you tomorrow over at u pull it? Need to go over there anyway?
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
That would be great bud, I finish work at 330 so I could be down there for about 430ish. If u can't make that time it's no probs at all. I should eventually figure it out haha
Bigjohn84
May 5, 2015
2,330
Mate I can be down there for 4.30pm that's perfect, I'll message you on this at 3/3.30pm to make sure ur coming, I'll be in a silver cupra also.
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
Sweet, thank you very much, I don't have a vag com unfortunately.
Another reason I don't think the exhaust is the problem is because before I changed it to de-cat and 3" DP, it made the same noise. Bloody strange! 07753112183 is my number just in case I don't get 3G at work tomorrow
Bigjohn84
May 5, 2015
2,330
I've no cred mate so if you can't make it you txt me on 07521673553 and let me know, txt me say 3.45pm if ur not coming, I'll be there 4.30pm if I don't get a txt of you, I'll try top up tomorrow. And try get my mate vag com also.
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
Okay doke mate, il defo be there around 430 :D thanks again!
I better get to sleep or il not be awake before 430! Haha
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
It did cross my mind mate but the noise I definetly from the mid to front of exhaust. I thinking it may be my oil pick up pipe which I haven't replaced before
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
Ah I see, I might buy a good sports car then.
Is that what u did?
LCR
Bwwaaaaapp
Jul 3, 2014
163
Fife
Ah right suppose il just need to live with it, would rather the extra 3bhp
Gaz7
385
Have you checked turbo to manifold gasket, and have you checked manifold is not cracked?
