facelift headlights on a pre facelift car??
sykes1990
61
leicestershire
Hi all
so Im in the middle of retro fitting my new xenon headlights, got them bolted in and all working.. went to re fit the bumper and it just wouldn't fit, just ever so slightly out?? tried setting/adjusting the mounts but nothing? got it back on at one point but didn't look right against the wing.. so would these be the headlights to fit the facelift spec??:confused:
sykes1990
61
leicestershire
Well i brought them and they were just advertised as mk2 Leon headlights?? to be fair its that close Im thinking about taking the car to the body shop and have the front bumper slightly altered ... or can you get a face life btcc style bumper??
DAZFR72
279
In The Van
Facelift btcc bumper are available from the stealers !! Check flee bay as fl cupra bumpers also pop up .
wjohnson
211
So is it confirmed that they changed the headlight design for the facelift then? I'm finding it hard to believe when the altea uses the same parts?
markmeus
Mark Graham
Jun 9, 2007
2,948
11
Banbridge, Northern Ireland
They facelifted the Altea too - so they probably both still use the same headlights, just different versions.
Having said that I'm not sure if they are different or not, but I think the consensus is that the facelift ones are.
1,044
North East, UK
Yes ... on FL cars they changed the front head lights.
They also changed the rear boot lid and light cluster.
sykes1990
61
leicestershire
Oh right, well think Im going to alter the bumper slightly
. having another problem though with the bulbs, the side lights and xenon works fine but the indicators and main beam don't????
May 25, 2008
1,919
S.Wales
www.seatcupra.net
Gutting ....because with FL-Lights =
New Bumper (Which you can get in BTCC...)
But you will also need new side wings to go with the FL Lights and FL Bumper
Pretty sure I seen it on piston-heads before 08 Leon FR spend £££ on it...(in Red)
Please correct this if I am wrong though :(
1,044
North East, UK
I think you may regret altering the bumper ... you will be better getting a FL one!!
How much has it cost you for the Xenon conversion??
paul7619
158
LLanelli
Whats so good about those lights for nearly 400 pounds. Are they so much better than standard. If you went for looks you should of got those Dectane devil headlights for half the price
