Facelift Leon FR
JenDTUK
Hi guys,
any idea where i can find the OBD port on our facelift Leon FR?
Jen
jezyg
2,330
28
Yes is under the rotary light switch saw it when they used VAGcom to try and set up the OEM Seat satnav on our FL Leon.
wesbar
65
19
Have you had the RNS510 fitted to your Leon? I know it has been done on the old model but cant find any info on whether this is possible with the Facelift Leon.
jezyg
2,330
28
Sort of is the word, it fitted and worked ok except for the MFD and steering wheel controls. They think it needs the latest firmware to work so are going to put on the latest firmware and will then reinstall it. If that works then yes it will be a simple plug and play affair about 15mins to fit!!!. Will keep you posted......
wesbar
65
19
Forgot to ask. Did OEM Retrofits supply the new double DIN fascia? Did you have to go to their workshop to have it fitted or did they come to you?
jezyg
2,330
28
Thanks , nope you need to soucre the fascia as there are quite a few in different shades ours is code DS Grey. They met us at J23 services as once amonth they will meet you anywhere on the M1 corridor.They were both nice and knowlegeable chaps the units are re-conditioned but all genuine. I gave the local dealer my VIN to get the correct one and the fascia cost £16.20 inc VAT.
