Fan Problem
PlatinumR
Arrived and lovin it!!
Jul 23, 2004
253
Shoreham-by-Sea
yep, common as muck.
On the Leon both fans should run slowly with the air con on so that air is drawn across the aircon rad.
trouble is the low stage fails either in the fan itself or the controller (?) which then causes the high speed system to kick in to satisfy the aircon demand. Problem is the high speed draws alot of current and blows the fuse on the battery meaning you have no fans at all!!!
If your fans run very noisy every 20 seconds or so with aircon on then it needs sorting!
Mine did it and it needed new fans.
Ju.
461
Bradford
I think mine does this, have noticed the main fan coming on very regular, must check!!!!!!
paul h
360
Lincoln
if the fans pulsate rather than spinning slowly when the aircon is turned on then they are buggard i'm afraid.they should run constantly at a slow speed.
Ju.
461
Bradford
Mine definately don't run all the time , only in short bursts!!
Sounds like a trip to the dealers..................JCT600:cry:
paul h
360
Lincoln
is yours still in warranty ?? the golf ones where £200 for the fans + fitting which most did themselves
Ju.
461
Bradford
Yes, it's still in warranty (just over 2 years old), but I don't like going to JCT600!!!.
I heard there was a new dealer opening in Huddersfield soon, so I might hang on for a bit
Thanks for your help though:)
andyjayh
Glad I saw this thread, I've been listening to my fans come on and off every couple of minutes on my journey into work. Pondering whether it has always been like that and I just hadn't noticed :redface:
First thing I did as I got to work today, phone the dealer and book it in on Friday :funk:
WaveyDaveyGravy
But I'm so tasty
Jan 3, 2006
350
11
Shipley
Mine does this too - problem started last year in summer. When I switched the engine off with the air con on there was a strange vibration/noise - knew it was a cooling thing as the engine wasn't running, but now I know why!
Just have to add it to the ever-growing list of things to fix at imminent service...
andyjayh
Got mine back from the dealers on Friday, new set of fans required :( Good thing it's still under warranty :D
WaveyDaveyGravy
But I'm so tasty
Jan 3, 2006
350
11
Shipley
Has anyone got anywhere with this? My dealer said there was nothing wrong with the fan at service today, but it's been doing the same thing with the fan for 6 months now. Obviously it depends on the ambient temp which at the moment is cool, hence it's less of a problem. I'm pretty disappointed it didn't get picked up, but is it possible for the fans to be ok and the control unit to be buggered?
Ju.
461
Bradford
Took mine down to the new Seat dealership in Huddersfield today and they've booked it in for 2 new fans fitting under warranty on friday:)
Must say it was quite refreshing to go into a helpful dealership, there also going to replace all the R badges too:funk:
Julian
