Fan speed resistor keeps blowing
alex.o.d
10
I have a 2007 seat leon 1p and the resistor that controls heater fan Speed keeps blowing and will only work on 4 max speed does anyone know a cause and how to fix this problem
Sent from my GT-N7100 using Tapatalk
T J Hooker
21
Check that the fan blade/rotor is not stiff to turn. If the shaft is dry or the bearing is on the way out then the motor strains to turn it and the resistors end up going.
Sent from my SM-G900F using Tapatalk
T J Hooker
21
It happened on my wife's altea. I learnt the expensive way. After that lesson, a few squirts of wd40 or some similar lubricant solved the problem.
