fluffy01016
1.21 Gigawatt !!
Feb 20, 2005
249
13
Lincoln
I know this question has been done many times before but most the links look to be outdated now and I was hoping someone could confirm which part I need to add fan jets to my Cupra ST300. I don’t think it has heated jets as they only come with heated seats?
thanks in advance
Obviously you need to buy 2
If your car came with the winter pack/has heated seats, washer fluid level low indicator/headlight washers then it will also have the heated jets.
Thanks. I’ve not got headlight washers or heated seats so looks like I’ve not got heated washers then. I’ve ordered the new fan washers and hope they’re better than the rubbish ones that are standard fit
I think you'll know if you have a wire connection to the jets. if it's just the fluid tubing they're not heated.
Changed them two days ago. Can confirm the fans are much better. And way easier to ajust. Go for it :)
