jb1978
I'm thinking about buying a Cupra but upon scanning it with VAG.com it came up with the below fault codes. Everything else about the car seems pretty solid and it has a 12 month MOT etc. Are these anything to worry about?
Thanks for any advice!
VAG-COM Version: Release 409.1-S
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
Controller: 06A 906 032 DE
Component: 1.8L R4/5VT 0001
Coding: 11510
Shop #: WSC 06441
3 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
17072 - ECM Power Relay Load Circuit: (J271): Open
P0688 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0021505
Shop #: WSC 00001
No fault code found.
Address 08: Auto HVAC
Controller: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00041
Shop #: WSC 06441
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1M0 920 901 D
Component: S5-KOMBIINSTR. VDO V03
Coding: 05414
Shop #: WSC 06441
IMMO-IDENTNR: SEZ7Z0Y0773875
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
Address 46: Central Conv.
Controller: 1J0 959 799 AH
Component: 8N Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 06441
8 Faults Found:
01331 - Door Control Module: Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
00941 - Exterior Mirror Retract Motor: Driver Side (V121)
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
00912 - Window Regulator Switch: Front Left (E40)
27-10 - Implausible Signal - Intermittent
01332 - Door Control Module: Passenger Side (J387)
00944 - Heated Exterior Mirror: Passenger Side (Z5)
35-00 - -
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
End --------------------------------------------------------------------------------------------------
could be old fault codes. should have cleared them and re run the test. most of them are intermitant so prob have been fixed and the n249 could be a boost leak if i remember right
Tried to clear them but my vag.com said it needed a professional interface to clear. Thanks for the advice!
once u clear them they will come up again with in few hours or next day. don t buy until is sort out the faults .
cheek into readiness to to see lambda sensor and cat?
if anyone has a autodata can help u with more answer about the faults
cheers
