daves ibiza
hi guys ive been trying to source this out for ages . puting vac through bulkhead as mine is currently going through door/wing ect . reason is i dont trust myself with water going through vac pipes as im using washer bottle in boot. and dont want it bursting on wires ect[:@]. many thanks guys
are your wires covered in Plastic coating? If so... how will they get wet?
Use a continuous piece of pipe & there are no weak points.
yes i no that . i just dont want it to burst split ect . over loom and stuff i have new vac line but just where to locate it:(
I used my old man car arial, or a coat hanger would do the job. (metal of course), does the job in seconds.
under the scuttle panel,driver side behind the wiper motor
when you lift the plug up you can see day light if you lay in the driver foot well and look up past all the pedals ect ect
