5509433
949
7
Braintree, Essex
Hi all,
I will be going through a stage of refurbing some alloys soon. I plan on getting them shot blasted and then powder coated.
A few of the wheels have kurbing and also chunks taken from the face.
What is the best filler to use (when necessary) for shot blasting?
I don't want to make the wheels look perfect, and come shot blasting, have them destroy the filler!
When you pay professionals, what do they use to overcome such damage?
So I'll need to get them sorted professionally then?
Dammit. I suppose it will save me money if I do the majority of the sanding on scratches?
Photos of some damage.
I was going to clean them before powder coating, but them realised that shot blasting is the cleaning process...doh!
Will the shot blasting correct all curbing and other dents and damage? I don't see how it will cure dents, and the part of the rim that is out of shape.
It would probably be better if you could do the filling/sanding after the shot blasting but before the powder coat. Shot blasting will not magically fix the damage, it'll simply clean the whole wheel. If you then powder coat chances are that damage may show through.
That alloy wheel filler would be fine prior to powder coat, but the powder coat will be so much better if the wheel can get shot blasted first.
Ok. Went to the coaters today. Showed him the pictures. I mentioned about the filler, and he said as long as it is a metal filler, it will be fine.
Of the other hand, I did some more research and came across braising. I may give that ago. Undecided.
Another question.
When people have used standard filler as they are only painting them, when it comes to getting the tyres installed, has the filler ever been damaged?
I've used 'Metalik' before with some success. Availble from halfords, mix the hardener into the paste in a pea:golf ball ratio.
Just be sure to be quick, i'd say you get about 5 mins max before it starts to dry and becomes hard to apply.
