Hi has anyone fitted the cat back exhaust to there car and is it a easy job or would you recommend a garage instead?
HiHi has anyone fitted the cat back exhaust to there car and is it a easy job or would you recommend a garage instead?
Yes it sounds better, not too loud and no drone really sitting at a steady 70mphHi, are you happy with the result? Improved sound? No drone?
Thanks,
Hi Guys, you can hear a bit of it here :Hi, are you happy with the result? Improved sound? No drone?
Thanks,
Nice result
No peeling for the moment?
I heard that results are sometimes disappointing because the coating is not lasting as long as it should (even with high temp coats because of the condensated exhaust gaz acidity)
Do you have the same resonance in normal mode between 2500 & 3000?
