Honda crf
Hi boys. What kinda job is it to remove stock suspension and fit coilovers. Am a kinda competent lad is it a amature job.
fitting them id say yes probably hardest part is lower nuts but abit of heat always helps, setting said coilovers up on the other hand will be left to people with the correct tools
Ok spot on. The bottom nuts were not long replaced because a front spring snapped so I got both changed. Thanks for reply.
