wezy0 wezy0 leon lc Nov 10, 2009 488 0 westyorkshire Sep 18, 2013 #81 an u also need hope that helps u can new the a3 one I just think they are 2 strong hope that helps
wezy0 wezy0 leon lc Nov 10, 2009 488 0 westyorkshire Sep 19, 2013 #83 Mikeyfraser said: This where I have the fixings. Are these in the right place? Click to expand... That top one is ok
Mikeyfraser Active Member Jul 25, 2013 142 0 Sep 19, 2013 #84 Does the bottom one need moved or is it okay?
Mikeyfraser Active Member Jul 25, 2013 142 0 Sep 19, 2013 #86 Thanks for the help got it sorted now. Got one off an a3 bonnet.
jake I AV MOSTLY BEEN BEATING Feb 2, 2003 2,666 1 rochdale Visit site Sep 19, 2013 #87 tried this today, and kind of failed, the strut has to fix into the ball but its on too much of an angle for this to work so i modified the way its works and went the oem solution i still used the plates, 20x50mm, welded the nut on the back, how ever i went through the hinge heres the hole IMAG0223 by cuprajake1, on Flickr after that to allow the strut to come down you have to trim this piece IMAG0225 by cuprajake1, on Flickr remove it IMAG0227 by cuprajake1, on Flickr cut in half IMAG0228 by cuprajake1, on Flickr install upside down IMAG0218 by cuprajake1, on Flickr i also trimmed the rubber 1/2" this is it fitted up, no more bonnet stay IMAG0215 by cuprajake1, on Flickr IMAG0232 by cuprajake1, on Flickr IMAG0220 by cuprajake1, on Flickr IMAG0221 by cuprajake1, on Flickr the struts are off an audi a4 13" long, while they hold the bonnet they dont lift it, so i need something stronger which i can have made by a company
Benzy Active Member Jan 30, 2010 1,203 3 Sep 29, 2013 #89 Looks great, I would prefer them hidden than coming from the front of the bay. Might have to look into this
