I'm fitting my H&R springs tomorrow. Ive noticed most of the guides Ive seen on the internet say you have to remove the hub nut and remove the outer drive-shaft and ball joint to get the strut out. Is this true, as it will be the first suspension kit Ive fitted than needed the drive-shaft out. Usually there has been enough vertical movement to get the strut out.
Anyone done their own that can shed some light??
