fixing caliper
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
ive a knock at the back of my ibiza mk4 , when pulling off from a stop , and 4 some reason i think it might be a sticking caliper , gonna do a wee test later when a mate drops his axles stands over , was wondering how hard it is to replace the seals etc , or would spray lube n moving the piston in n out do
cheers
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
the car is too new to have dried out the grease in the piston, sounds like either your pad is on its way our or your h/brake isnt fully releasing until you move off.
stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
it does it brendan , even if u use the footbrake , plus theres loads left on the pads , will try copper greasin the pads see if that helps ,
