stoneyfordNI
GGG GGG GGGIGITYYY
Jan 9, 2005
2,673
Lisburn NI
ive a knock at the back of my ibiza mk4 , when pulling off from a stop , and 4 some reason i think it might be a sticking caliper , gonna do a wee test later when a mate drops his axles stands over , was wondering how hard it is to replace the seals etc , or would spray lube n moving the piston in n out do
cheers
the car is too new to have dried out the grease in the piston, sounds like either your pad is on its way our or your h/brake isnt fully releasing until you move off.
it does it brendan , even if u use the footbrake , plus theres loads left on the pads , will try copper greasin the pads see if that helps ,
