captain, excuse my ignorance, but ive never owned a set of springs where the paint has stayed on?!
I had eibach springs on my bmw and the paint didnt last long at all... same with my jamex coilovers on my leon...
With covers of course! :)
I don't see the point myself. Having to take the covers off to clean them all the time, in fact more, due to all the crap collecting in the cover? rather just clean them well
The hot tuning ones have three year warranty as well ;)
You should work for hot tuning :p aha mate get some and give me the feedback!!
We sell loads of the JOMs and for a budget kit it's one of the best out there.
Give me a shout if you need any info or prices.
Damian @ DPM Performance
will PM you mate!
i have FK coilovers, and they were on the car 18months (before i owned it) and when i MOT'd it ALL of the shocks were leaking, the seals perished etc.
I researched it and seems to be a common thing with some FKs. they were horrible ride aswel, but that could have been the shocks.
I went with Jamex Coilovers, £150 i think... not the best but better than my FKs
doesn't look like i'll be settling for them any time soon then!
Then I still need to change my droplinks I think?! or are they ok?
Lol just going by what I've found and they've come out on top so far in the under £250 range if I could afford £400 then I'd spend it but I can't ;)
Because the eibach and Jamex coatings are sh*t I've run kw and Weitec springs and coilovers for years and never seen it flake off!!
Tell you what I'll send you a set and you'll see that if you fit to a new set of coilovers they will be brand new under the cover after a year!
I make these myself, and they work a treat, the design is patented so no copying!
Captain Cupra where did you get the covers from?
I make them, F**k the haters they work mate, people don't see the point but the causes of shock surface and spring wear is down to dirt and grit getting between the springs wearing the coating away and also sitting in the shock seals, not only that they keep the dirt off the threads so when you want to adjust you don't grind half a ton of grit.
I make them, F**k the haters they work mate, people don't see the point but the causes of shock surface and spring wear is down to dirt and grit getting between the springs wearing the coating away and also sitting in the shock seals, not only that they keep the dirt off the threads so when you want to adjust you don't grind half a ton of grit, I can make you a set for £30 delivered.
Thanks for the info and the offer mate, think I may give it a go myself. Sounds good in principle, dont see why they wouldnt work!
I wouldn't mind a set for my new coily's when they get ordered ;) aha
i'm running JOM's, wound them all the way down but have had to wind them up a bit, cos i couldn't bear the grinding noise of the ARB on the drive shaft !!
gonna get a whiteline arb soon, goes under the drive shaft so can go all the way down. only thing in my way will be arches lol
