Forge DV 007 spring rate
Noam
182
Anyone know what would be the ideal spring on runnig 18 PSI of boost on a k03??
Red or Blue?
Thanks in advance.
flashbsd
im on blue as ive not changed back to yellow/green, whats the difference? i thought it was onyl a problem if your running higher boost and a weak spring,, not the other way round.
flashbsd
coolio, but does it matter im runnign stiffer on lower boost?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
too stiff a spring like blue and the DV wont open properly...
you need a DV which has enough spring pressure to seal, but is as easy to open (fast) as possible.
I have tested a gree spring for leak to 22psi when I heard the faintest of hisssss, like you would never feel in real driving terms.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
not necessarily, ive been running a yellow spring for a year and a half remapped and non remapped, makes bugger all difference to a green really so not worth the effort to change.
Tallpaul
821
So with a REVO or Jabba generic remap is it right that you should change to a Yellow spring?
I've run both the Yellow and Green on my REVO Audi A3 1.8T (150bhp Stock so comparable to a Beeza). Couldn't tell the differance between them on the road but had the Green one in for my RR run and it made 192bhp/218lb_ft and didn't appear to be bleeding boost in the slightest. So no need for the yellow one IMO.
